Hi All,
I was going a bit crazy writing scripts for NCM without syntax highlighting, so I made a highlighting file for Notepad++ (my editor of choice).
This will highlight all of the operators, keywords, and SWIS entities that I could find by combing the documentation. To get an idea what it looks like, here is a screenshot:
This may be incomplete! It works well on the scripts that I have tested, but to be honest the documentation for the script language is a maze of twisty passages, all alike.
If you have any feedback, corrections, or additions, please post them and I will update it.
To install and use the file in NP++, follow these steps:
- Download the sw-ncm.xml file
- In NP++, go to Language->Define your Language
- Click Import... and select the sw-ncm.xml file
And that's it. I hope someone finds this useful. If it is popular, I will upload the autocompletion definition I am working on that will automatically search for SWIS entries while you are writing a script.
