The sample script returns 1 if the number of directories within a specified path is
greater than the number of specified within the command.
If the difference is less than or equal to the specified number, the script will return a 0.
Sample Monitor Settings
For the following example, we will assume the following:
Path: \\WebSrv1\dirs\
Maximum directories allowed: 300
Script Location: c:\ipmscripts\
For Windows 2000
Executable Name: cscript.exe
Directory: c:\winnt\system32\
Command Line Parameters: dircount.vbs \\WebSrv1\dirs\ 300
Startup Directory: c:\ipmscripts\
Compare the Process Return Value = SELECTED
Expected Return Value: 0
For Windows XP / 2003
Directory: c:\windows\system32\
The sample script is not supported under any SolarWinds support program. The
sample scripts are provided AS IS without warranty of any kind.
