Hi Guys,
I wanted to have my Nortel/Avaya Core Switch with details below as NTA source. I read thru the KB and came across this:
Configuring Nortel devices for use with Orion NTA
Nortel has provided an IPFIX Technical Configuration Guide to assist in the configuration of your Nortel IPFIX-enabled devices.
but when I click on the link, it says server not found. Maybe the data has been moved to a different location. Any help on this?
These are the details for my switch:
! Base model = Ethernet Routing Switch 5650TD
! Base Software version = v6.2.3.010
!Stack Base Unit = 1
! Stack info:
!Unit# Switch Model Pluggable Pluggable Pluggable Pluggable SW Version
! Port Port Port Port
!1 5650TD (49) SR (50) None v6.2.3.010
!2 5650TD (49) SR (50) None v6.2.3.010
Thanks and best regards,
Aaron C. Garcia
