My problem is
When i Create any operaton from within IP SLA MANAGER , Orion will automatically use the IP address that it communicates with the Node on, as the IP address that will be inserted into the Node Confiugration for that Operation.
This is a problem in our network as the IP address that Orion contacts the Node with is a NAT'd address that does not physically exist on the Router, Therfore the Operation fails everytime, unless i manually alter the configuration on the Node myself.
Is there anyway around this, other than creating the operations myself and just monitoring those operations. from Orion
Regards
