Hi All,
I have an application that is defined only by about 30 HTTPS monitors. Most of the monitors work but when one of the first few montors times out the lowest few monitors error out with the message
"Connection timeout. Previous monitor(s) used whole application job time. No time to run this one."
I have extended the application polling timeout from 5 sec to 20 sec but I am not sure this is the setting that will correct this issue. Is this the correct place to fix this issue or is there another setting for the total allowable monitor time?
Thanks - Andy
Affinion Group
