Currently using EOC 1.2 sp1 with three environments pointed to it. I have already imported all the maps from the three separate environments and all is fine. Problem comes when a map was altered and I run the map convert utility on the EOC server. I get the option to overwrite, convert, or skip. I check overwrite option and the process completes successfully. When I check the map on the EOC server, its the same old map.
My workaround is to open Atlas and delete the maps I know have been modified and then us the convert utility on EOC to import the new maps. Although this works, its very time consuming with the load times for Atlas and number of maps ( if I have many that have been altered ).
Is this working as intended or a bug ?
