I am performing an intial setup of SRM in an environment that has a previously setup environment of SAM and NPM. Should the install of SRM go on the same server and use a seperate database?
SRM is Orion based module, so if you have NPM with SAM installed, you can install also SRM on the same box and you can also use the same database. Just make sure you are not mixing beta versions of any these products together, and your installation should be fine.
Also there is an general recommendation to backup your database prior initiating setup, but I suppose you are aware of
In order to additional review, you can reply NPM and SAM versions you have installed and SRM version you'd like to install. I can verify steps of integration or help you more detailed.
Regards
Lubo
Hi campbellj1977!
One other thing you could do is check the recommendations shown in the SolarWinds Product Upgrade Advisor. It will tell you what you need to install, and in what order, to get your SRM integrated
Product Upgrade Advisor | SolarWinds Customer Portal
