I'm wondering the reason why certain settings in Serv-U Management show as bold text and others dont?
See Attachments.
Craig
It means that that value is overriding the default value set for that setting. As it appears in your screenshots, those are settings for your domain. If you go and look at the settings for your server, those specific settings will have the opposite value of your domain's settings.
