So, now that we have installed NPM10.1.2 we are required to use Network Atlas 1.5 and EOC 1.3 RC6 is not compatible with that version. Looks like Network Atlas 1.4 is the compatible version but we make maps in both systems.
Now, that wouldn't be a problem if I could install both versions but when it detects the other version it either overwrites it or tells me I have a newer version installed and exits out.
Is there a way to run both versions without having to uninstall the other?
