hi folks:
I have many sql instance to be put on DPA for monitoring and alerting. Is there any script to help as manual process is killing me...
thanks
Yes, we have a Mass Registration feature you can use and it's documented here: Register multiple database instances - SolarWinds Worldwide, LLC. Help and Support
FYI, we are also working on adding an API for managing the DPA environment, so look for that in an upcoming release as well.
