I am unable to manage a new client on our network
Source: Data Grid Server (SBSUTILITY02)Device: demerson.sbs.nycnetDetails: Computer connectException occurred at 5/24/2011 10:34:58 AM: Attempt to connect to demerson.sbs.nycnet failed.The following attempts were made:
ARP Resolution result: NoDNS Resolution result: YesNETBIOS Name Resolution: YesMS Endpoint Mapper: YesWMI Connection: No
Call was canceled by the message filter COM Exception: Error Code: 0x80010002 . Unable to connect using account DEMERSON\administratorEminentWare Provider Connection: No
Call was canceled by the message filter COM Exception: Error Code: 0x80010002 . Unable to connect using account DEMERSON\administratorFile and Print Sharing Ports: Yes
Successfully connected to direct hosting NetBIOS over TCP-IP port 445 which is required for 'File and Print Sharing'
Any advice or assistance would be appreciated.
Thank you.
Omar
Verify you can currently ping the machine by name.
Verify that the account specified in the error is an admin to that machine
From the EminentWare Server machine:
If you are unable to connect using wbemtest:
Check the firewall on the client machine:
To check that DCOM in enabled - From the client machine:
-Sean
I am having this exact same error.
i am able to succesfully connect using wbemtest.exe to the server.
however when i try to run a report now or go to any tab in computer explorer i get the following error
Source: Data Grid Server (STRW007021)
Device: pdgmsoad02.mso.net
Exception occurred at 3/13/2012 12:58:02 PM: Attempt to connect to pdgmsoad02.mso.net failed.
WMI Connection: No
COM Exception: Error Code: 0x80010002 . Unable to connect using account mso\msoadmin
please help thanks
Can you access the machine with the System Information tab of Computer Explorer?
The reason this is significant is that the System Information tab does not require the EW WMI Provider to be present. If that tab fails to connect, we can focus our efforts on core WMI issues, rather than ExtPack specific issues.
One scenario in which I have seen this message generated is when an intervening firewall is blocking access to the WMI Ports. In fact, it happened to me. I had my firewall configured to allow access on ports 1024-3999, which in most instances should have been sufficient for a Win2003 client machine. However, as it turned out, the RPC EM assigned a port higher in the grid and the connection was failing because the firewall was blocking it. (I had replaced that client machine recently, so it's also possible that the previous machine had been customized to only use 1024-3999.)
More details on the specific port requirements for WMI can be found in the white paper EminentWare Components, Communications, and Required Ports.
