Hello,
I am evaluating SAM 5.0 and I am trying to get the SNMP monitor to work using OIDs that I currently use in NPM. I am using some of the most basic OIDs for HP disk drives and Dell DIMMs to test since I know they work in NPM. I must be doing something wrong - each test I do when I create the monitor comes back with "No Such Name".
Here's a snip of the current configuration for an HP disk OID:
It's got to be something simple. The server tested works fine for the built-in hardware monitoring. Obviously I won't need to add a disk OID, but since I knew it worked in NMP and SAM this is what I wanted to test with. I get the same result when testing a working Dell DIMM OID against a Dell machine.
