When I try manage a device (via Workspace Studio) using a known SNMP string I get credentials failed. When I perform Switch Port Mapper on the same switch and check use assigned credential again "Credential test failed". When I select an existing credential (same credentials as assigned) or manually enter a community string it works. I'm using the same community string every time. So far it only happens on Enterasys switches but not every one.
