I'm trying to import a list of 800 monitors from one IPM instance to another. My problem is basically that during importation, IPM doesn't keep the group->device relationship (all checkboxes are checked during export and import)
Weirdly enough, SOME groups have the correct devices inside of them, while most of them are empty.
Also, all the groups appear in the "Orphaned Objects", while the unassociated devices appear under "My Network"
No errors during the importation process either..
Is there anything I can do to fix this?
