I am relatively new to the Orion SDK.
Using Visual Stuio 2010, C# and the Orion SDK I have connected to my Orion server.
Using SWISv3: servername:17778/.../v3 for my service reference.
#Code
var binding = OrionBinding.Binding;
var address = new EndpointAddress(string.Format("https://{0}:17778/SolarWinds/InformationService/v3/OrionBasic", hostname));
ServicePointManager.ServerCertificateValidationCallback = (sender, certificate, chain, errors) => true;
var client = new InformationServiceClient(binding, address);
if (client.ClientCredentials != null)
client.ClientCredentials.UserName.UserName = username;
client.ClientCredentials.UserName.Password = password;
client.Open();
#Code
I am able to read and update Orion node details.
#Code
//Read DNS property
var dns = client.QueryXml(string.Format("SELECT DNS FROM Orion.Nodes WHERE NodeID= '{0}'", NodeId), null);
//Update DNS property
var dict = new dictionary { new item { value = "12345", key = "DNS", type = "System.String" } };
var uri = string.Format("swis://{0}/Orion/Orion.Nodes/NodeID={1}", hostname, nodeId.Value);
client.Update(uri, dict);
#Code
I am able to update Orion node Customer Properties.
#Code
//Update CustomProperty
var uri = string.Format("swis://{0}/Orion/Orion.Nodes/NodeID={1}/CustomProperties", hostname, nodeId.Value);
var dict = new dictionary { new item { value = "12345", key = "CustomProperty", type = "System.String" } };
client.Update(uri,dict);
#Code
However, I cannot seem to read Orion node custom properties.
The following code results in the following exception when "client.Read" is executed.
#Code
//Read
client.Read(uri);
#Code
#Exception
The formatter threw an exception while trying to deserialize the message: There was an error while trying to deserialize parameter http://schemas.solarwinds.com/2007/08/informationservice:ReadResult. The InnerException message was 'Element value from namespace http://schemas.solarwinds.com/2007/08/informationservice/propertybag cannot have child contents to be deserialized as an object. Please use XmlNode[] to deserialize this pattern of XML.'. Please see InnerException for more details.
#Exception
#Inner Exception
{"End element 'value' from namespace 'http://schemas.solarwinds.com/2007/08/informationservice/propertybag' expected. Found text '6146'. Line 1, position 392."}
#Inner Exception
The '6146' is my Orion NodeID.
Any help on this would be much appreciated.
Cheers,
Luke.
