We are planning on enabling bitlocker, but I am not sure if Serv-U will still work after that? Is there any conflict if we encrypt the hard drive?
I don't think we've ever tested with bitlocker. But, I think it should be fine- everything I know about bitlocker says that it is transparent once authenticated.
The only thing I can think of that would be different is timing. Running everything through the encrypt/decrypt layer might slow things down a bit.
If you are concerned, I'd enable it on a test server & try it there before putting it into production.
I would appreciate if you can update us after your testing.
I apologize for the confusion-
I meant to say that if you are concerned about this feature, you should try it on a test server. It should not take too long for you to set up & run it through how your business uses serv-u. I don't know your setup, or how your business works, so I can't test it
