Using PM 2.1 and we have moved form POC to production. I'd like to move the PM DB from the local SQL Express installation to a remote full blown SQL 2008 R2 instance. Is this supported and if so is there a guide?
Hi Shocko,
This link here should help you out:
Migrate a local or remote Patch Manager database to a Remote SQL Server - SolarWinds Worldwide, LLC. Help and Support
/Derek
