I have just downloaded and installed the latest RC NTP version and have some issues and questions:
1. I can no longer de-select a node so that it is not displayed on the map. There is no longer a checkbox (just a green tick?) in discovered nodes next to the node, to hide it on the map..
2. Icons are now resizable which is great but the text is still minuscule (unreadabile) at the Zoom above 60% and cannot be resized. Text can be moved but is there a way to increase the font or re-size the text block?
