Hi all;
I'm Facing with below issue, somebody can help?
Process Request Exception: Exception running work process PID: 0 : à Rove.MobileAdmin.Core.PageDispatcher.ProcessRequest(HttpContext context)
Regards
After looking a bit, and not finding anything on that, I recommend you open a new Case with SolarWinds Technical Support. That way you have them working on your behalf while the Thwack folks try to beat them to the answer for you.
Swift Packets!
Rick S.
