Is there a way to setup Orion/Solarwinds to allow viewing of network map only?
l would like to remove all tabs from the Solarwinds view and only allow users (Tier 1) the viewing of the network map/topology.
I would recommend that you create a new Summary page just with the map as the resource, then create a DirectLink Account and remove all tabs and views from the account and select the new Summary page just with the map. This way you can send out just the URL to the new Summary page and when they access the details they will see the map without needing to authenticate.
