Is it possible to install an additional Orion Poller on the same box that is running EOC?
That should be possible. You may have to install EOC first and then the additional poller.
In the installation instructions it says it possible when installed on the NPM server except if it is running 64bit. Does the same hold true for the poller? We have a second poller and we're looking at moving to 64 bit but I don't want to setup another server for EOC if possible.
The 64bit conflict was related to the EOC and Orion websites, so this is not an issue if you are installing an Orion Poller.
EOC SP1 addressed this issue to allow EOC's website to install in a mode that allows it to run on the same web server as Orion. This however depends on the EOC installation occuring after the Orion installation.
That is perfect! Thanks for the response!
I was worried about moving it and affecting everyones links, now it looks like we'll be ok.
Thanks for the quick response!
