I want to query all my systems and determine which ones have which version(s) of Java. Can anyone give me a little nudge or 2?
Just run the Installed Programs and Features report under Configuration Management reports. Select Installed Programs and Feature Basic and select Programs and Features under Data Sources. When the report has completed under the Display Name heading click on the filter icon, click on Text Filter and click on Contains, change the filter to read Display Name Contains Java and click on OK.
Import this report I made. You can input whatever search term you want I.E. Java and it will report with OS and IP everything with Java
Intalled Programs with OS and IP.xdq
