I tried to setup the "Directory Service Query" connector within LEM and input the incorrect port that we use to connect to our domain controller. With the other connectors, I can simply go into Manage > Appliance then on the appliance select "Connectors". From there choose to edit the connector and select "Stop". Then I would be able to make changes to the connector, or remove it all together. For the Directory Service Query connector, when I click "Stop" nothing happens. It just stays in "running" status. I've clicked stopped repeatedly, and no change. Is there any other way to manually shut down this connector so I can correct it?
When I try to edit it while it's running, all I get is the normal greyed out settings screen. Which is how it usually is when a connector is running.
