I've been asked to generate a report for NetFlow data, that will pull info for devices between the 16th of Month A to the 15th of Month B.
They'd like to also see weekly reports, finishing with a month end report.
This is the SQL commands for the data I am working with... the example below shows a 30 day interval, but I am not sure how it comes up with the numbers.
SELECT TOP 10000 FlowCorrelation.FullHostname AS Full_Hostname, FlowCorrelation.IPAddress AS IP_Address, Nodes.Caption AS NodeName, SUM(NetflowEndpointsSummary.TotalBytesDst) AS SUM_of_Bytes_Transferred_Rx, SUM(NetflowEndpointsSummary.TotalBytesSrc) AS SUM_of_Bytes_Transferred_Tx, SUM(NetflowEndpointsSummary.TotalBytes) AS SUM_of_Bytes_Transferred_Total, Nodes.NodeID AS NodeID FROM (NetflowEndpointsSummary LEFT OUTER JOIN FlowCorrelation ON (NetflowEndpointsSummary.IPSort = FlowCorrelation.IPAddressSort)) INNER JOIN Nodes ON (NetflowEndpointsSummary.NodeID = Nodes.NodeID) WHERE ( DateTime BETWEEN 41553 AND 41584 ) AND ( (FlowCorrelation.FullHostname LIKE '%mycingular.net%') ) AND ( (EXISTS(SELECT 1 FROM NetFlowSources WITH(nolock) WHERE NetFlowSources.InterfaceID=InterfaceID AND NetFlowSources.Enabled=1)) ) GROUP BY FlowCorrelation.FullHostname, FlowCorrelation.IPAddress, Nodes.Caption, Nodes.NodeID ORDER BY 6 DESC |
