I am configuring netflow on our Cisco 6509 and I am new to this.
I need to be able to capture flow data for VLAN 744 and 900 because users at the other end of those networks are having some slowness issues and I want to find out what is going on before I delve in and fiddle with stuff.
None of the interfaces (vlans or otherwise) are behind the FWSM.
It seems that I am unable to issues the IP FLOW INGRESS command on the following physical interfaces: gi 1/44, gi 4/24 and I'm not sure why. There is a FLOWCONTROL ON/OFF [send] [RECEIVE] [DESIRABLE], but I don't think that has anything to do with netflow...(I might be wrong).
I am seeing netflow data from TONS of interfaces, including vlan 744, but the really interesting traffic that I need to see is on VLAN 900, but of course, I don't have any data from VLAN 900.
Can anyone help me out?
IOS version: s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF9, RELEASE SOFTWARE (fc1)
I have the following commands in the MSFC:
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination [0.0.0.0] 2055
ip flow-cache timeout active 1
ip flow ingress layer2-switched vlan 744,900
<<just put this one in to see if it makes a difference>> ip flow ingress layer2 vlan 900
mls ip multicast flow-stat-timer 9
mls aging long 64
mls aging normal 64
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
<<On int gi 1/44:>>
interface GigabitEthernet1/44
description [description]
switchport
switchport access vlan 744
switchport mode access
no ip address
logging event link-status
spanning-tree portfast
end
<< on int gi 4/24:>>
switchport access vlan 900
no ip address
mls qos trust dscp
<< on int vlan 744:>>
interface Vlan744
ip address [0.0.0.0 0.0.0.0]
ip flow ingress
ip route-cache flow
standby ip [0.0.0.0]
standby priority 120
standby preempt
standby authentication *******
<< on int vlan 900:>>
interface Vlan900
no ip redirects
no ip proxy-arp
ip flow ingress
ip route-cache flow
