Hi All,
Have one query on SRM.
What is the main Difference between Storage Orion Module and Profiler Module? I went through the guide but still not able to distinguish.
Can any one throw some light into this....
Going to toss a few links for you to look at. In a nut shell SRM Orion is a newer ground up product with native Orion suite integration over Profiler.
Dreams Come True - Storage on Orion is now in Release Candidate!
Differences between SRM Orion and SRM Profiler - SolarWinds Worldwide, LLC. Help and Support
Storage devices supported
If you still have questions let me know.
Hi mbussey
Thanks for the links..helped in understanding it better.
So basically SRM orion is made native to bring everything into one pane. Features wise i guess both the module are same, correct me if i am wrong.
And i also feel it can help in kind of load balancing to monitor from both the modules...but yea polling will be from both ends towards the device.
Hi, the third link you provided "Storage devices supported" doesn't seem to be valid? http://www.solarwinds.com/documentation/en/flarehelp/srm/content/orionsrmagaddarray.htm
Try these instead:
Supported Storage Devices - Storage Resource Monitor | SolarWinds
Which arrays are supported by SRM and SRM Profiler?
