When I try to connect to a XP PC I get the following error " Waiting for the initial screen". I did come across articles that say you must change registry entries. Another article suggest that you should upgrade Dameware.
I did not even try those solutions, because my colleague is using the same version of Dameware on the same OS as I do. He can connect to the XP Pc while I cant connect to the same PC.
Is there any solutions to this problem, maybe an obscure setting.
