How can you scan the hosts on your network to figure out which ones are missing the LEM Remote Agent?
Thanks.........Rick
Assuming you are trying to identify which Windows servers do not have the LEM Agent on it, you can use something like Dameware Remote Support and use it's exporter feature to dump an excel file on the software inventory
Remote Support Software | DameWare
If you have SAM, it can also do a software inventory scan for both Windows and Linux/Unix hosts.
http://oriondemo.solarwinds.com/Orion/NetPerfMon/NodeDetails.aspx?NetObject=N%3a574&ViewID=408
Going forward, you can set it up to automatically deploy it on new servers
SolarWinds Knowledge Base :: Using the SolarWinds LEM Local Agent Installer non-interactively
Thank you for the response, one question, that button that says Scan for New Nodes, will that show me any machines that don’t have the LEM agent?
Rick
The 'Scan for all nodes' scans the logs received and saved by LEM's Syslog server, and matches the connectors for the logs received. It doesn't scan the network to find out which servers do not have an agent.
