We are using SolarWinds with Azure SQLMI , whether as a default the SolarWinds will take care of basic SQLMI monitoring or i need to configure in DPM ?
AppInsight for SQL will potentially give you some metrics though not all as it also relies on WMI and host metrics. API rest pollers against azure will give you some and normal SQL component queries will work.
But if you want deep down info with out of the box support for SQLMI, I really recommend DPA.
