I’m having an issue with Engineer’s Toolset on SolarWinds Platform 2026.2.2 (Windows Server 2022).
When launching Toolset from any node, I receive either:
- HTTP 500 Internal Server Error
- “Your session has been terminated”
The issue affects all nodes. The Toolset license is valid, SNMP credentials test successfully, and interfaces appear correctly under List Resources.
I have already:
- Run the Configuration Wizard
- Reinstalled SolarWinds/Toolset components
- Checked IIS bindings and application pools
- Tested with different browsers and a local admin account
The main SolarWinds web console works; the issue appears specific to Toolset.
Has anyone seen this issue? Which Toolset/IIS logs or backend service should I check to identify what is causing the HTTP 500 and session termination?
Thanks.
