Our HA environment continues to be a split-brain where the additional poller thinks it is a standby. Is there a fix in the works for this as it doesn't seem to be reliable.
A bit confused. So, you have an HA environment with a primary and secondary server. Then you have an "additional poller" that is showing in standby?
Or, do you have one of the new "poller pools", which isn't really HA. But, a poller pool has to have at least 3 servers, 2 of which will be active and one in standby…
They are two very different things. An "Additional Poller" has nothing to do with an HA pair of servers. But, as of 2026.2.1 the poller pools allow you to have a pool of additional pollers in a highly available configuration.
