Hello Folks,
So i have the bgp and ospf pollers added for all layer 3 devices running bgp/ospf, only issue is the alerting i get for anything bgp/ospf is very generic, basically all it shows is "neighbor x.x.x.x on node y went down" and basically thats it for both bgp and ospf. This is from the default built in neighbor down alert which i guess is not detailed enough.
So what variables do i need to choose in the subject field under trigger actions (which is where we usually set up the email alerting) so that it shows all the details like neighbor hostname and the interface that it failed on etc (this is what i see on catalyst center by default which we also use for our cisco devices).
I'm sure there must be specific variables that i can select for this right?
Thank You
