Hello,
I am investigating an SNMP issue observed in a production environment where snmpbulkwalk intermittently fails with the following error:
Error: OID not increasing
TCP-MIB::tcpListenerProcess.ipv4."127.0.0.1".53
This occurs while walking the TCP listener table (.1.3.6.1.2.1.6.20).
Environment:
- OS: AlmaLinux <version>
- Kernel: <uname -r>
- net-snmp: <snmpd -v>
Test setup:
- Configured SNMP with full MIB access (
view all included .1) - Generated multiple TCP listeners (via
nc and local services) - snmpbulkwalk -v2c -c <community> localhost TCP-MIB::tcpListenerProcess
Observed behavior (test environment):
- SNMP walk completes successfully
- Output appears correctly ordered
- Unable to reproduce the error
Observed behavior (production):
- Error: OID not increasing
- Appears to be tied specifically to
tcpListenerProcess
Workaround applied:
Excluding the subtree resolves the issue:
view limited included .1.3.6.1.2.1
view limited excluded .1.3.6.1.2.1.6.20
Questions:
- Under what conditions can
tcpListenerProcess return non-monotonic or duplicate OIDs? - Is this a known limitation/bug in net-snmp when walking kernel TCP tables?
- Could this be caused by race conditions while reading
/proc/net/tcp or similar kernel interfaces? - Are there known kernel versions or high socket churn scenarios that trigger this behavior?
- Is there a recommended way to reliably reproduce this issue for testing?
Additional notes:
- The issue appears intermittent and environment-specific
- Suspected interaction between SNMP walk timing and dynamic TCP socket state
- Reboot temporarily resolved the issue in production
Any insights into root cause or reproduction strategies would be greatly appreciated.
Thanks.
