Hi All,
Where can i see the speed of interface which is discovered in SolarWinds via SNMP ?
Node Details > Interface Details
Yes for aruba devices which are discovered via api is not showing the interface speed
SWI needs to have SNMP access, and the end node also needs to support the specific requests. You mention it isn't finding it via API but you didn't share your API request? FWIW - Aruba is a part of the HPE "environment" and like HPE then depending on the specific end device they don't always have everything enabled.
when you edit the interface you can see the Custom Bandwidth, its the speed,
its appear on interface details
