Hi there, is it possible to monitor ARR values like Health Status, Reponse Time, Total Requests, Load Balance via AppInsight IIS?
I don't think you can include it under AppInsight for IIS as its a bundle.
Rather try creating a separate SAM template using Windows Performance counters components, maybe you will get the required output that you are looking for.
There are 2 counters for ARR, check Step 2 on the below link and try getting that on SAM template through Windows Performance counters.
Using Performance Counters | Microsoft Learn
Thanks @vinay.by creating a SAM Custom Template with Performance Counters worked great for this requirement!
Thank you, could you please mark my previous response as answered/correct (Did this answer the question?Yes) as this would help others on community who has a similar query :)
