I have setup JMX on my JBOSS server. I am able to connect to it using Jconsole without incident. I can also browse the presented MBeans through component monitor wizard and get results. So I setup a new template with one MBean that I want to monitor, run the test and it connects and comes back as "up". When I add the same host to the newly created template (using the jmx component I just created and tested successfully) it sits in the state of "initial poll in progress". The jmxbridge.log file gives me:
2016-03-16 13:40:45,808 [mainhread] INFO com.solarwinds.jmxbridge.Service - JMX Bridge started.
2016-03-16 13:40:45,824 [jmxbridgehread] INFO com.solarwinds.jmxbridge.Service - Publishing JMX bridge web service on 127.0.0.1:9191/jmxbridge.
2016-03-16 15:21:13,387 [pool-1-thread-1hread] INFO com.solarwinds.jmxbridge.JMXSessionCache - Connecting to 'service:jmx:rmi:///jndi/rmi://192.168.5.4:8686/jmxrmi'...
2016-03-16 15:21:14,559 [pool-1-thread-1hread] INFO com.solarwinds.jmxbridge.JMXQueryService - Created session e7f848c0-ac4b-44fe-85c2-ac287a6f3287 for 'service:jmx:rmi:///jndi/rmi://192.168.5.4:8686/jmxrmi'.
2016-03-16 15:21:14,762 [pool-1-thread-1hread] INFO com.solarwinds.jmxbridge.JMXSessionCache - Closing session e7f848c0-ac4b-44fe-85c2-ac287a6f3287
2016-03-16 15:21:21,521 [pool-1-thread-1hread] INFO com.solarwinds.jmxbridge.JMXSessionCache - Connecting to 'service:jmx:rmi:///jndi/rmi://192.168.5.4:8686/jmxrmi'...
2016-03-16 15:21:21,552 [pool-1-thread-1hread] INFO com.solarwinds.jmxbridge.JMXQueryService - Created session a532cad8-a701-402c-bd2c-f7e518f9516a for 'service:jmx:rmi:///jndi/rmi://192.168.5.4:8686/jmxrmi'.
2016-03-16 15:21:21,568 [pool-1-thread-1hread] INFO com.solarwinds.jmxbridge.JMXSessionCache - Closing session a532cad8-a701-402c-bd2c-f7e518f9516a
2016-03-16 15:21:32,349 [pool-1-thread-1hread] INFO com.solarwinds.jmxbridge.JMXSessionCache - Connecting to 'service:jmx:rmi:///jndi/rmi://192.168.5.4:8686/jmxrmi'...
2016-03-16 15:21:32,365 [pool-1-thread-1hread] INFO com.solarwinds.jmxbridge.JMXQueryService - Created session 67694929-1da2-4c5b-99ee-aa7f2eeb9934 for 'service:jmx:rmi:///jndi/rmi://192.168.5.4:8686/jmxrmi'.
2016-03-16 15:21:32,521 [pool-1-thread-1hread] ERROR com.solarwinds.jmxbridge.JMXQueryService - getBeanInfo failed for session 67694929-1da2-4c5b-99ee-aa7f2eeb9934, object 'jboss:service=invoker,type=http,target=Naming,readonly=true'.
java.rmi.UnmarshalException: error unmarshalling return; nested exception is:
java.lang.ClassNotFoundException: org.apache.xerces.dom.DeferredElementImpl (no security manager: RMI class loader disabled)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:198)
at com.sun.jmx.remote.internal.PRef.invoke(Unknown Source)
at javax.management.remote.rmi.RMIConnectionImpl_Stub.getMBeanInfo(Unknown Source)
at javax.management.remote.rmi.RMIConnector$RemoteMBeanServerConnection.getMBeanInfo(RMIConnector.java:1081)
at com.solarwinds.jmxbridge.JMXQueryService.getBeanInfo(JMXQueryService.java:183)
at com.solarwinds.jmxbridge.JMXQueryService.getBeans(JMXQueryService.java:154)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:71)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:275)
at com.sun.xml.internal.ws.api.server.MethodUtil.invoke(MethodUtil.java:68)
at com.sun.xml.internal.ws.api.server.InstanceResolver$1.invoke(InstanceResolver.java:235)
at com.sun.xml.internal.ws.server.InvokerTube$2.invoke(InvokerTube.java:134)
at com.sun.xml.internal.ws.server.sei.SEIInvokerTube.processRequest(SEIInvokerTube.java:73)
at com.sun.xml.internal.ws.api.pipe.Fiber.__doRun(Fiber.java:1121)
at com.sun.xml.internal.ws.api.pipe.Fiber._doRun(Fiber.java:1035)
at com.sun.xml.internal.ws.api.pipe.Fiber.doRun(Fiber.java:1004)
at com.sun.xml.internal.ws.api.pipe.Fiber.runSync(Fiber.java:862)
at com.sun.xml.internal.ws.server.WSEndpointImpl$2.process(WSEndpointImpl.java:404)
at com.sun.xml.internal.ws.transport.http.HttpAdapter$HttpToolkit.handle(HttpAdapter.java:706)
at com.sun.xml.internal.ws.transport.http.HttpAdapter.handle(HttpAdapter.java:260)
at com.sun.xml.internal.ws.transport.http.server.WSHttpHandler.handleExchange(WSHttpHandler.java:98)
at com.sun.xml.internal.ws.transport.http.server.WSHttpHandler.handle(WSHttpHandler.java:82)
at com.sun.net.httpserver.Filter$Chain.doFilter(Filter.java:79)
at sun.net.httpserver.AuthFilter.doFilter(AuthFilter.java:83)
at com.sun.net.httpserver.Filter$Chain.doFilter(Filter.java:82)
at sun.net.httpserver.ServerImpl$Exchange$LinkHandler.handle(ServerImpl.java:675)
at sun.net.httpserver.ServerImpl$Exchange.run(ServerImpl.java:647)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.ClassNotFoundException: org.apache.xerces.dom.DeferredElementImpl (no security manager: RMI class loader disabled)
at sun.rmi.server.LoaderHandler.loadClass(LoaderHandler.java:396)
at sun.rmi.server.LoaderHandler.loadClass(LoaderHandler.java:186)
at java.rmi.server.RMIClassLoader$2.loadClass(RMIClassLoader.java:637)
at java.rmi.server.RMIClassLoader.loadClass(RMIClassLoader.java:264)
at sun.rmi.server.MarshalInputStream.resolveClass(MarshalInputStream.java:214)
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1613)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1518)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1774)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1351)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:371)
at java.util.HashMap.readObject(HashMap.java:1396)
at sun.reflect.GeneratedMethodAccessor19.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1017)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1896)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1801)
at java.io.ObjectInputStream.access$300(ObjectInputStream.java:206)
at java.io.ObjectInputStream$GetFieldImpl.readFields(ObjectInputStream.java:2157)
at java.io.ObjectInputStream.readFields(ObjectInputStream.java:541)
at javax.management.modelmbean.DescriptorSupport.readObject(DescriptorSupport.java:1347)
at sun.reflect.GeneratedMethodAccessor18.invoke(Unknown Source)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1993)
at java.io.ObjectInputStream.defaultReadObject(ObjectInputStream.java:501)
at javax.management.modelmbean.ModelMBeanAttributeInfo.readObject(ModelMBeanAttributeInfo.java:504)
at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
at java.io.ObjectInputStream.readArray(ObjectInputStream.java:1707)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1345)
at javax.management.MBeanInfo.readObject(MBeanInfo.java:693)
at sun.rmi.server.UnicastRef.unmarshalValue(UnicastRef.java:326)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:175)
... 41 more
2016-03-16 15:21:32,552 [pool-1-thread-1hread] ERROR com.solarwinds.jmxbridge.JMXQueryService - getBeanInfo failed for session 67694929-1da2-4c5b-99ee-aa7f2eeb9934, object 'jboss:service=invoker,type=http,target=Naming'.
... 41 more
2016-03-16 15:21:32,599 [pool-1-thread-1hread] ERROR com.solarwinds.jmxbridge.JMXQueryService - getBeanInfo failed for session 67694929-1da2-4c5b-99ee-aa7f2eeb9934, object 'jboss:service=proxyFactory,target=ClientUserTransaction'.
... 41 more
2016-03-16 15:21:32,630 [pool-1-thread-1hread] ERROR com.solarwinds.jmxbridge.JMXQueryService - getBeanInfo failed for session 67694929-1da2-4c5b-99ee-aa7f2eeb9934, object 'jboss:service=WebService'.
java.lang.ClassNotFoundException: org.jboss.mx.util.MBeanProxyInstance (no security manager: RMI class loader disabled)
Caused by: java.lang.ClassNotFoundException: org.jboss.mx.util.MBeanProxyInstance (no security manager: RMI class loader disabled)
at sun.rmi.server.LoaderHandler.loadProxyClass(LoaderHandler.java:556)
at java.rmi.server.RMIClassLoader$2.loadProxyClass(RMIClassLoader.java:646)
at java.rmi.server.RMIClassLoader.loadProxyClass(RMIClassLoader.java:311)
at sun.rmi.server.MarshalInputStream.resolveProxyClass(MarshalInputStream.java:255)
at java.io.ObjectInputStream.readProxyDesc(ObjectInputStream.java:1559)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1515)
... 41 more
2016-03-16 15:21:32,662 [pool-1-thread-1hread] ERROR com.solarwinds.jmxbridge.JMXQueryService - getBeanInfo failed for session 67694929-1da2-4c5b-99ee-aa7f2eeb9934, object 'jboss:service=NamingProviderURLWriter'.
java.io.WriteAbortedException: writing aborted; java.io.NotSerializableException: org.jboss.bootstrap.microcontainer.ServerImpl
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:193)
Caused by: java.io.WriteAbortedException: writing aborted; java.io.NotSerializableException: org.jboss.bootstrap.microcontainer.ServerImpl
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1355)
