Hi all,
I’m on SolarWinds 2025.x and have one PDU node (Geist) that will not use the custom Node Details view I created. Most nodes my team works with are Cisco devices, so our team Summary view normally makes sense — but for this one PDU, I need a different view.
The problem:
This node always loads our team’s Summary view:
Network Team – Geist IMD3 – Summary
No matter how I open it.
The correct view only loads if I manually force the ViewID:
/Orion/NetPerfMon/NodeDetails.aspx?NetObject=N:14666&ViewID=484
What I’ve tried
- Added View Limitation by Manufacturer (Geist Manufacturing)
- Machine Type is correct
- Changing Device Category doesn’t help
Still always loads the wrong Summary view.
Main issue
The page that should control this:
Settings → Views by Device Type
…never loads. It just times out with:
System.Web.HttpException: Request timed out.
So I can’t adjust or clear the device‑type → view assignment for this one node.
Looking for
Has anyone seen ViewsByDeviceType.aspx timing out in 2025.x and causing a node to get stuck on the wrong Summary view?
Any UI‑only workaround to reset the view mapping for a single device?
I do not have server/SWQL access.
Thanks!
