You could use a try/catch block to collect the error and write it to a text file.
But my guess is that SQL Server authentication is failing. Since you are not specifying a username/password, I'm guessing that Invoke-SqlServerQuery is using Windows authentication. When you run the script as yourself, your AD account is authorized to query that database so it succeeds. When the script runs as a trigger action, it is running under local system context. This means it accesses SQL Server as the machine account, which probably doesn't have access to your database.
Thank you for the response. I am going to work on this first thing tomorrow and let you know how it turns out
