Hi guys,
Can anyone help me importing this xml in modern dashboard?
I am getting an error while importing this.
Hi WinterSoldier,
Here's the SolarWinds KB article on how to upload/download dashboards into SolarWinds.
https://documentation.solarwinds.com/en/success_center/orionplatform/content/core-fusion-dashboard-import-export.htm
The assumption to this KB article is that you have SWQL Studio installed. If you do, then all you need to do is the 3 import steps:
Orion.Dashboard.Instances
Orion.Dashboards.Instances
Import
<Return>...</Return>
definition
If done correctly you'll get a message that looks something like this:
- <Fault xmlns="http://www.w3.org/2003/05/soap-envelope">- <Code> <Value>Sender</Value> </Code>- <Reason> <Text xml:lang="">Orion.Dashboards.Instances.Import failed, check fault information. Value cannot be null. Parameter name: key</Text> </Reason>- <Detail>- <InformationServiceFaultContract xmlns:i="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://schemas.solarwinds.com/2007/08/informationservice"> <Message>Value cannot be null. Parameter name: key</Message> </InformationServiceFaultContract> </Detail> </Fault>- <Fault xmlns="http://www.w3.org/2003/05/soap-envelope"> - <Code> <Value>Sender</Value> </Code> - <Reason> <Text xml:lang="">Orion.Dashboards.Instances.Import failed, check fault information. Value cannot be null. Parameter name: key</Text> </Reason> - <Detail> - <InformationServiceFaultContract xmlns:i="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://schemas.solarwinds.com/2007/08/informationservice"> <Message>Value cannot be null. Parameter name: key</Message> </InformationServiceFaultContract> </Detail> </Fault>
Plz let me know if you run into any issues. If you do, I'll post the SWQL script, which will work, but you won't have the icons that I selected for the dashboard view. But I can help you with those too if you want.
I am getting this error.
<Text xml:lang="">Orion.Dashboards.Instances.Import failed, check fault information. Unexpected character encountered while parsing value: x. Path '', line 0, position 0.</Text> </Reason>
<Message>Unexpected character encountered while parsing value: x. Path '', line 0, position 0.</Message> </InformationServiceFaultContract> </Detail> </Fault>
I often get errors like this, but the dashboard gets uploaded anyway. I would go to manage dashboards and search for your new dashboard. If it's not there then here's the SWQL query:
SELECT n.Caption AS [System Name] , CASE when s.ScheduleTask.ScheduleType is NULL then '' ELSE s.ScheduleTask.ScheduleType END as [Schedule Type] , CASE when s.ScheduleTask.AccountID is NULL then '' ELSE s.ScheduleTask.AccountID END as [Suppressed By] , CASE when s.ScheduleTask.name is NULL then '' ELSE s.ScheduleTask.name end as [Suppression Description] , CASE when s.ScheduleTask.Reason is NULL then '' ELSE s.ScheduleTask.Reason END as [Suppression Reason] , CASE WHEN s.ScheduleTask.NextRun is NULL then '' ELSE TOSTRING(TOLOCAL(s.ScheduleTask.NextRun)) End as [Scheduled Date] , CASE WHEN n.UnManaged != 'False' then 'Unmanaged' ELSE '' END as [Unmanaged] , CASE WHEN n.UnManaged <> 'False' then TOSTRING(TOLOCAL(n.UnManageFrom)) ELSE '' END as [Start Unmanage] , CASE WHEN n.UnManaged <> 'False' then TOSTRING(TOLOCAL(n.UnManageUntil)) ELSE '' END as [End Unmanage] , CASE when z.ID like '%' then 'Muted' ELSE '' END as [Muted] , CASE when z.SuppressFrom is NULL then '' ELSE TOSTRING(TOLOCAL(z.SuppressFrom)) End AS [Start Mute] , CASE WHEN z.SuppressUntil is NULL then '' ELSE TOSTRING(TOLOCAL(z.SuppressUntil)) End AS [End Mute] ,n.DetailsURL AS [Details URL] ,n.Status ,n.VendorIcon FROM Orion.Nodes AS n left join Orion.ScheduleEntityAssignment s on n.uri = s.EntityUri left JOIN orion.AlertSuppression z on N.Uri = Z.EntityUri where s.ScheduleTask.Enabled = 'TRUE' and (s.ScheduleTask.NextRun is NOT NULL) or (n.UnManaged != 'False') or (z.ID like '%')
I often get error like this, but the dashboard gets uploaded anyway. Have you searched for the new dashboard yet? Just in case here's the SWQL query.
Thank you for providing this SWQL. Does this query differs from version to version? This swql works on v2025.4 but it throws an error on v2025.2.1.
