hi all - need help on SWQL for KPI widget for hardware components in critical state - thanks
Hi Jason, we need some more information to offer the Help. What type of Hardware (windows/Linux Server, Network Device(if poss what type of device) and what component)
and what platform SHO or Saas
hi - if would be for multiple vendors cisco & windows (for now) component would be for all Hardware devices - i do have this in a table widget but i need it just to specify for company =**** via custom properties (**** being the company name)
SELECT n.Caption AS [Node Name] ,n.DetailsUrl AS [_LinkFor_Node Name] ,'/Orion/images/StatusIcons/Small-' + n.StatusIcon AS [_IconFor_Node Name] ,hi.name as [HW Device] ,'/Orion/images/StatusIcons/Small-'+hi.StatusDescription+'.gif' as [_IconFor_HW Device] --,hi.DetailsUrl AS [_LinkFor_HW Device] ,hi.OriginalStatus FROM Orion.Nodes n inner join Orion.HardwareHealth.HardwareItem hi on hi.NodeID=n.nodeid WHERE -- n.nodeid= ${nodeid} hi.StatusDescription not in ('up','unknown')
Basically, you need to create a SWQL Select statement that provides a number to each KPI box in the KPI object. So for nodes in critical state this should work:
SELECT Count(H.NodeID) AS Critical
FROM Orion.HardwareHealth.HardwareInfo H
JOIN Orion.NodesCustomProperties C ON H.NodeID = C.NodeID
WHERE StatusDescription = 'Critical' AND C.Company = 'Your Company Name'
Thank you - just what i needed😀
HP ProCurve Switches Hardening check.xmlGeneral hardening for HP switches
