Hi
Has anyone successfully changed the certificate on the Management Console?
I have found that these two files regenerates if you remove them
Serv-U-DefaultCertificate-Ver.2.crt and Serv-U-DefaultCertificate-Ver.2.key
And my problem is the law and customer demands, so is there a way to change them in order install my own SSL cert and get rid of the warning of self signed certificate (and to be compliance with the law)?
