Hi all, I’m new to SolarWinds and would like to know how to automatically add nodes to a group when new nodes are added
@sonubaba Yes can be done.
Below link will help you.
How to Create Groups Using Dynamic Queries - Video
Let me if you need any help
@naveensingh43 thanks it usefull let me look.
It's fairly straightforward to do this. Go to: Settings > All Settings and under 'Node & Group' select Manage Groups.
Find the group you want [sorry, no search here] and tick the box - but make sure only the one box is ticked - n.b. manage groups is very good at ticking things you didn't think you had so be ultra cautious when deleting groups.
e.g.
Once ticked, from the top menu bar select 'Add & Remove Objects' and then 'Add Dynamic Query'.
BTW: you probably won't need to want to change from Node as the object, but there are plenty of options if you do
Once happy with the results, Save and then Submit.
