PCI, here
Mmm...no points for correct answers.
It seems like that has been the case for the whole mission.
ya, I haven't received points for any question this mission.
@network_defender the team has recognized this in the main mission comments.
Try STIG, SCSEM, PCI and IRS Pub 1075
PCI-DSS, HIPAA, HITECH... it's my life at this point, haha.
HIPAA, PCI DSS, GDPR, SOX, SSAE-16, ISO, and the list goes on.....
As a consumer focused entity, this is an extremely important topic for all users. At my organization, this is paramount for securing the identify of all our consumers.
Same here no points ...
@gmilan see above response.
Mostly PCI.
\m/
need to demostrate, compliance in the requirement, 12.3 that the protocols has to encrypt securely like sem and SCM.
