Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Setup paging with network performance monitor
alonzo-garza
Hello all, Inside the solarwinds network performance manager I've set up an alarm to e-mail as well as page me when a node goes down but I'm not receiving the pages. I have a metrocall pager issued from work and I set up the alarm to page me with my # (example) 3333333333@page.metrocall.com Does anyone know of any issues with paging from this software or why it would stop working? When I page myself through Microsoft Outlook using the same 3333333333@page.metrocall.com I immediately get the page; so something is not right with the software! Please if anyone can help I'd appreciate it. Thanks, ~ZO
"Fail to plan and you plan to fail" - Unknown Author
Find more posts tagged with
Accepted answers
All comments
Bryan
What happens if you just set up the alarm to send you an email to your Outlook? Do you get it? If that works, there is no reason you shouldn't get the page. Is the computer part of your domain? If not you may need to install IIS and set up a SMTP relay pointer so your server knows where to send mail.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
Network_Guru
Your Paging/SMS Service Provider may only accept mail from a valid
e-mail address/domain. Do you have the "from" field filled out with a valid domain as well?
or
Your SMTP server for outbound mail, may not be the same one Outlook
uses to send mail.... ?
-=Cheers=-
NG
one_w_borg
I do not see where you stated your Mail routing gateway. If the Mail gateway is not correct or does not allow mail from the SolarWinds machine than the messages will not go out.
Have a great day,
Locutus
Locutus Of Borg
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
