Are you on the latest version of the Orion® Platform products? Learn how to find and download the offline installer, prepare for the upgrade, enable the upgrade to your products and agents, and finally, how to confirm and check your upgrade.
Resources:
About Installing or Upgrading Orion Platform Products and Scalability Engines
Activate Licenses for Orion Platform Products
Upgrade Older Versions of Orion Platform Products
Network Performance Monitor: From Version 10.5 to 2020.2
Orion Platform Products Installation and Upgrade Guide
SolarWinds Upgrade Resource Center
Orion Platform 2020.2 Release Notes
SolarWinds 2020.2 Upgrade Resources
Product Upgrade Advisor
Orion Platform Migration Guide
