Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Switch Port Mapper Versions
cshiver
In researching an issue I have with switch-port mapper I noticed that there seem to be a number of different versions of the tool out there with which people are having varying degrees of success.
The issue I have is that running against a Catalyst 6500 running CatOS 7.6 I get full populations of MAC and IP addresses, but I only get names for the first couple of hundred devices. If I re-run I get similar results. Unfortunately the ports my user closets are on are low numbered so the table gets filled up with desktop names.
Any thoughts?
- Chris
BTW running 5.6 from September '03.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
The names are retrieved by doing a "Reverse DNS Lookup". You can check to see if the names are actually in the DNS PTR zone by doing a "ping -a <IP.Address> from a Windows PC.
You can also do an nslookup from the command prompt on your EE server and enter the IP Address of a node which did not resolve to a name.
Either the IPs are not in DNS, or the DNS queries are timing out. Perhaps your DNS server has some kind of flood control if too many queries come from one host in a brief period of time?
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
