People often need a solid justification in terms of return on investment (ROI) while making a purchase decision. With increasing complexity in IT infrastructure, administrators are asked to do more with less, as well as show a tangible ROI for investment made on IT, by rightsizing their network management system. How do you assess the effectiveness of an NMS for higher ROI? A cost-benefit analysis can quantify your total cost of ownership (TCO) and help you to understand the potential long-term benefits.
Why Is It Important to Calculate ROI of your NMS Implementation?
Organizations implementing network management and monitoring software are experiencing strong ROI, improved data analysis and reporting, and faster time-to-resolution for network issues such as downtime and performance bottlenecks. Determining the right solution for your company not only requires finding a tool that satisfies your current priorities, but also the way it can adapt to your future IT needs.
Learn How to Calculate ROI
The Slideshare below will help you to understand more about calculation ROI for Network Management and Monitoring.
https://www.slideshare.net/slideshow/embed_code/27097614
Benefits of Higher ROI in NMS!
ROI for an NMS can be realized across a number of areas as follows:
- Salary/Staff Time Savings
- Reduced Network Downtime
- Reduction in Support Calls
- Decreased Time-To-Resolution
- Managing Service Level Agreements
Learn More
This ENTERPRISE MANAGEMENT ASSOCIATES
(EMA
) white paper examines the importance of finding extensible, cost-effective network performance management solutions that fit deployment needs.
"Features and capabilities aside, the best way to understand both product fit and Total Cost of Ownership (TCO) advantages of replacing an existing network performance management solution with SolarWinds
NPM is to learn from the experiences of those who have made the switch."- Enterprise Management Associates
Who is EMA?
Enterprise Management Associates (EMA) is a leading industry analyst and consulting firm that specializes in going “beyond the surface” to provide deep insight across the full spectrum of IT and data management technologies.
Also, try the FREE network management ROI calculator from SolarWinds!!
