\m/
We work with some groups in India and they were having some issues with some data transmissions. They were saying it was something on our end then I pulled up NetPath and put in their site and let NetPath do its work and within 30 mins you could see that when the data hit routers/internet equipment in India is where the issues started. Needless to say I love NetPath!!!
Thanks for putting these out there!
