I have setup FTP Voyager with the SMTP settings for gmail to send an email after FTP Scheduler completes a task. I have added the event, send email after task complete, however I do not receive an email.
Any help would be appreciated
Regards
Nick
Hi Nick,
Have you created an email account for FTP Voyager to send emails from or have an email account fro FTP Voyager to use? For example, I created the email account FTP@companydomain.com. Without an assigned email address to use, FTP Voyager is not able to send any emails (i.e. there isn't an email account built into FTP Voyager).
Once you know what email account you will be using, you can enter that info into the Email Settings section of Scheduler Options, which is located in the Tools tab. If you are still running into issues, then there is something wrong with your scheduler.
- Zach
This is specifically a problem between FTP Voyager Scheduler and SMTP servers that require SSL-secured connections (such as those of GMail). This bug has been reported to our product team. In the meantime, as a mitigating step you could install an SMTP server on your network and use it to send out notifications from FTP Voyager Scheduler.
Thanks!
Thomas Parikka
Hi Thomas
Thanks for getting back to me.
So far I have got a work around using a batch script to create a log which gets emailed through LogMeIn, to avoid installing anything else on the computer, but if you could let me know when this bug has been fixed I'd really appreciate it
I'm having the same problem but different. I'm using windows server 2008 r2 standard and sql2005. Whether I created an action or event the ftp voyager log states that email was successfully sent but no email appears in Outlook. The only configuration that I have added is to placed our server name (not the ip address) in the email setting/server area. Any suggestions?
This is the same bug that nicke848 also posted. There aren't any workarounds - this is something that the developers will need to review for a fix.
