I would like to know/see if NTA can be configured so that it receives information from REMOTE Collectors that forward to the central site.
Other Vendors have this ability with the reasoning that collected data can go to the central site in blocks of data rather than stream the application server to death. They also provide for a SEPARATE database to handle the high amount of data and traffic.
Since Solarwinds does this for NCM, NPM and the poller for VoIP is separate, could thought be given to have a separate database for Netflow.
As others have mentioned in various threads on this site, with NTA running, SQL basically gets buried by the huge amount of incoming data. That is really not a good design to make NPM wait for another process.
Thanks for the help and consideration.
